On a DvR leaf node, you can configure a Management Instance VLAN by specifying the I-SID. Use the following procedure to configure a Management Instance VLAN on a DvR leaf node.
The following table defines parameters for the mgmt vlan i-sid command.
Variable | Value |
1-16777215 |
Specifies the VLAN I-SID to associate with the management VLAN. |
